588,201 active members*
5,116 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Power supply question
    Feb 2006
    13
    I am converting a Bridgeport series 2 Mill that originally had a boss of six control. I intend to to reuse the existing stepper motors connected to 202 drives and a G100 controlled by Mach 3. From what I understand these motors would be much happier running in the 72v range. My question is why is it recommended that you run a nonregulated power supply as opposed to a regulated one?
    Dec 2005
    3319
    They tend to be cheape and more robust due to their simplicity and low parts count.
    IT is pretty hard to screw up the functioning of a transformer, a diode bridge and a capacitor.
    THis is especially true when you're dumping all kinds of inductive feedback (indemic to any DC motor) into a P/S circuit - regulated P/S's don't like voltages being dumped back onto the regulated side of the P/S.
