588,172 active members*
4,215 visitors online*
Results 1 to 5 of 5
    Jul 2013
    4
    Power supply recomended
    Hello
    I am newbie in building cnc manchines, and I needed to know your opinion.
    I have 3 PK269JDA Vexta stepper motors, and a blue Chinese TB6560 controller board for 3 axes and was wondering what the recommended power supply for this set, if a 24v 15a is enough, or even stronger.
    thanks
    Márcio
    Jan 2010
    2141
    According to the spec sheet at ORIENTAL MOTOR GENERAL CATALOGUE 2-Phase Stepping Motors, that power supply should be OK for those motors when using the TB6560 controller board (2.8 A winding current), however the motors have a relatively high winding inductance of 5.7 mH which means that they really need a much higher voltage to get good speed without too much loss of torque (more than 70 volts would be needed, however the TB6560 can not handle anywhere near that high a voltage).
    Jul 2013
    4
    Quote Originally Posted by doorknob View Post
    Thanks in advance for your reply
    These motors are to build a homemade CNC MDF, I think the speed is not important for now, this is for a small hobby, not a large machine.
    Thanks again
    Márcio
    Dec 2005
    238
    A 15 amp power supply is more than enough current to drive 3 steppers and you are limited to 24 volts by the driver you have so the power supply you are looking at will do the job for you.
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
    Jul 2013
    4
    Quote Originally Posted by P.Passuello View Post
    Cheers
    Peter
    Ok Thanks
  1. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  2. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  3. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  4. Alarms at power up, 320v power supply fault?
    By locash in forum Haas Lathes
    Last Post: 01-10-2012, 06:35 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
