603,960 active members*
3,843 visitors online*
    Feb 2004
    466
    Power up sequence
    Hello all.
    I have these SD200 modules I wan tot employ in a router.
    Thing is, the modules have this specific power up / power down sequence that must be used.
    To power up I must
    1. apply 5V logic voltage with the ENABLE pin low
    2. apply motor PSU
    3. bring ENABLE up
    To power down:
    1. bring ENABLE low
    2. disconnect motor PSU
    3. disconnect logic PSU
    I have done it manualy while testing and I hope to work an automated way to do so. Maybe with relays. Frankly I am not sure how. Anybody can help out?
    Konstantin.
    Oct 2003
    593
    You could try using a time delay switch. Either build one, I've seen schematics on the web. Or, use one from an industrial control system. I've seen loads on ebay. They can be had in many different time ranges and are adjustable. They usually come to fit din rails.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
    Obviously you'll wan't only a short delay.
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Diy Power Supply Choices
    By berin in forum DIY CNC Router Table Machines
    Last Post: 07-13-2005, 09:47 PM
  3. Need more power
    By mvaughn in forum CNC Machine Related Electronics
    Last Post: 06-15-2005, 12:11 PM
  4. E-Stop Hard Wire and to Software?
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 10-30-2004, 05:22 AM
  5. Traco TSL480 48V Industrial DC Power Supply 10A
    By ullbergm in forum CNC Machine Related Electronics
    Last Post: 03-06-2004, 02:13 PM
