587,852 active members*
3,993 visitors online*
    Aug 2004
    8
    powermax 45 or 65?
    I am building a 4x8 cnc plasma table. I plan on only cutting steel of a thickness of 1/4" or less, probably 1/8 mostly. But if I had to I would like to be able to cut 3/8 or 1/2, although i really dont have any means of handling material that thick except maybe in smaller pieces. I am considering the pm45 and the pm65 for the table. I have seen it said that you should get as big of a unit as you can afford. I was wondering if there would be much advantages to buying the pm65 over the pm45 if I was mostly cutting thinner material? I am not running a production shop and it will just be used occasionally when I have a project going. Any advice is appreciated thanks.
    Jan 2008
    2247
    As far as the upper thicknesses goes....the 45 will do a good job on 1/2" material as long as your machine has a torch height control that has the ability to set a separate pierce and cut height. Of course the 65 will cut the thicker materials faster, and with less chance of dross.
    Other advantages of the 65:
    1. A new torch design with no moving plunger. Over time this will prove to be more reliable.
    2. Longer consumable life with the new torch design as used on the 65/85 systems.
    3. The 65 has a higher duty cycle rating.....helpful on thicker materials.
    4. The 65 has available FineCut consumables for cutting materials thinner than 3/16"....these consumables, not available on the 45, produce a finer cut kerf at lower cut speeds, which is helpful for producing more intricate parts.
    Jim Colt
  1. Powermax 85
    By magma-joe in forum Hypertherm Plasma
    Last Post: 12-11-2010, 12:39 PM
  2. Powermax 45 help
    By binfordw in forum Hypertherm Plasma
    Last Post: 12-07-2010, 06:37 PM
  3. 30 amp or 45 amp Powermax 45
    By adscnc in forum Hypertherm Plasma
    Last Post: 03-09-2010, 12:23 AM
  4. Powermax II Help
    By Bryanpl in forum Stepper Motors / Drives
    Last Post: 02-21-2007, 08:47 PM
  5. Powermax 2
    By crow in forum CNC Machine Related Electronics
    Last Post: 04-03-2004, 06:09 AM
