Hi everyone,
I am planning my CNC plasma build and have had the idea to run a powermax 45 on a 3-phase diesel generator, this would save me needing to get it permanently hooked up to my garage, and will be initially cheaper than paying an electrician to run new wires and another power meter etc. Also if i happened to move in the future, it would avoid the need to change the power supply configuration at the new location.
When selecting a generator, what should i specifically be looking for to avoid damaging the electronics of the powermax 45? I have been looking at this one but it may be too small for the power needs of the 45.
AGR Machinery | Genpower 8KVA Diesel Generator
its specs are:
AC Voltage: 240V/415 50Hz
Max. Output: 8.1kVA @ a power factor of 0.8
Rated Output: 5.0kVA @ a power factor of 1.0
DC Output: 12V - 8.3A
Alternator Type: Permanent Brushless Magnet
Output Type: 3x240v 15Amp, 1x415V 20Amp. Note: Each 240v outlet supplies approx 1/3 of the total generator output - e.g. 7amps
Engine Type: Single-Cylinder, 4-Stroke, Air-Cooled, Direct Injection Diesel
Engine Displacement: 420cc
Engine Max. Output: 6.3kW/3600rpm
Compression Ratio: 19:1
Fuel Consumption: 280 (g/kWh)
Fuel: Commerically Available Diesel or Compatible
Fuel Tank Capacity: 15L
Rated Continuous Operation: 8h (100% load) / 12h (50% load)
Oil Type: SAE 10W30 / Diesel Engine Oil
Oil Capacity : 1.65L
Noise Level at 7m: 74db
Enclosure: Super Silent Type
any and all opinions are welcome!
