603,969 active members*
3,151 visitors online*
Results 1 to 17 of 17
Hybrid View
Bryanpl PowerMax II connectors 06-10-2007, 10:27 PM
High Seas As I recall there was a... 06-11-2007, 02:17 AM
Bryanpl Yes, I privated messaged him... 06-11-2007, 06:20 AM
ger21 I got mine from Digi Key 06-11-2007, 02:59 AM
High Seas That answers the connector... 06-11-2007, 01:45 PM
Bryanpl Well, no luck so far. Hasn't... 06-17-2007, 11:02 AM
Bryanpl Do you recall the part... 06-12-2007, 07:35 AM
massajamesb I believe I got mine from... 06-11-2007, 02:32 PM
ger21 The part number can be found... 06-13-2007, 02:15 AM
acondit Bryan, The mouser part... 06-13-2007, 03:22 AM
Bryanpl How did you make the... 06-22-2007, 03:33 AM
acondit I used my manual mill. I... 06-23-2007, 05:51 PM
ger21 Connector... 06-17-2007, 12:36 PM
Bryanpl Gerry: Links don't work.... 06-17-2007, 11:13 PM
Pres Is this the correct... 06-18-2007, 08:53 AM
ger21 no. 06-19-2007, 01:51 AM
ger21 I got the number from the... 06-18-2007, 02:24 AM
    Jan 2007
    22
    Hi:
    Anybody have a source for connectors for the PowerMax II stepper motors.
    Sep 2003
    1113
    As I recall there was a member on the 'zone that was selling them. "Jeff" or something like that comes to mind. Try a want ad on the auction site? Its been a bit but there have been some on eBay as well - Hope that helps -- I'll look through my "stuff" and see if I can get closer....
    :cheers: Jim
    Ok a quick search and I got this for you : Its Jason ...
    http://www.cnczone.com/forums/showth...Max+connectors
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Jan 2007
    22
    Yes, I privated messaged him a number of months ago and never got a reply. From his profile his last post was back in 2004, so I don't think he frequents the board anymore.
    Quote Originally Posted by High Seas View Post
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2003
    1113
    That answers the connector source - and that was your question. But assembly for some requires an extra investment I'd rather spend on someone doing the work! $Kaching$
    But, if you are interested in the cables use the member look-up and follow thru to his eBay store. Most recent sale was April 2007. You can message him there. (you probably knew this already)
    I'm not trying to be a bit of a "Junior Dick" aka GumShoe -- I'll need some too!
    Sorry haven't emailed via eBay yet. Keep me posted and I you.
    :cheers: Jim
    DOOH - Lets do it easy: http://stores.ebay.com/Firey-Electronics
    Jan 2007
    22
    Well, no luck so far. Hasn't responded to private messages on this board or by the way of Ebay.
    :cheers: Jim
    Jan 2007
    22
    Do you recall the part number. How is the wire connected to the connector?. Do I need a special tool, or does the wire just snap into the connector?
    Mar 2006
    759
    I believe I got mine from Mouser Electronics, I think they were around a dollar each, maybe less.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Mar 2003
    35494
    The part number can be found in the PacSci .pdf at the Xylotex site.
    http://www.xylotex.com/PacSciDS.pdf
    Gerry
    Apr 2005
    1778
    Bryan,
    The mouser part number is 571-6438135. They are $.23 each at quantity 1 and $.21 each at qty 10.
    I made the insertion tool from an small screwdriver. I have attached a picture of the tool that I made and a pdf that gives the specifications for the official tool.
    Alan
    Attached Files Attached Files
    Jan 2007
    22
    How did you make the insertion tool, using a dremel ?. Is the insertion tool a necessity or can you use some small jewellery screwdrivers, to work the wire into the connector
    Quote Originally Posted by acondit View Post
    Bryan,
    Alan
    Apr 2005
    1778
    Quote Originally Posted by Bryanpl View Post
    I used my manual mill. I don't see why you couldn't use a dremel tool. I tried several times with other tools to do the insertions before I built the tool. Some people have succeeded but I found the tool to be the easiest thing for me. Since I built it I have used it a lot on other MTA-100 connectors.
    Alan
    Mar 2003
    35494
    Gerry
    Jan 2007
    22
    Gerry:
    Links don't work. Do you have the part number for the cover?
    Jan 2005
    224
    Gerry:Links don't work. Do you have the part number for the cover?
    Is this the correct connector?:
    http://rocky.digikey.com/WebLib/Weid...1715260000.jpg
    Pres
    Mar 2003
    35494
    Quote Originally Posted by Pres View Post
    Pres
    no.
    Gerry
  17. #17
    Mar 2003
    35494
    I got the number from the .pdf I linked to earlier in the thread, from the Xylotex site. It's at the end of the Powermax II section. Use the AMP number and it will come up at digikey.
    Gerry
  1. motors connectors
    By dan dimock in forum CNC Machine Related Electronics
    Last Post: 03-02-2007, 11:29 PM
  2. Powermax II Help
    By Bryanpl in forum Stepper Motors / Drives
    Last Post: 02-21-2007, 08:47 PM
  3. DB-25 Connectors
    By Nmbmxer in forum CNC Machine Related Electronics
    Last Post: 10-17-2005, 01:05 AM
  4. Powermax 2
    By crow in forum CNC Machine Related Electronics
    Last Post: 04-03-2004, 06:09 AM
  5. Powermax II stepper help?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-05-2003, 07:33 PM
