Grrr.... My employer VF-3 is acting strangely. The machine is 1998 vintage or so with 2-speed gearbox and 40 taper spindle. In high gear, no problem taking any cuts. The spindle load stays steady throughout a cut. In low gear, it is goofy. When cutting, the spindle load fluctuates 15% or so for no apparent reason even though the cutting parameters dose not change. Then there is times when it is really bad. The machine sometime sounds like a 4wd tractor plowing a field but it is only running 85-90% load. But if I override the machine to make the same cut in high gear, is runs smoothly. My employer says that we are to busy diagnose a problem that doesn't exist.
