603,940 active members*
2,172 visitors online*
    Aug 2008
    9
    Question Pre-Loading force
    I am building a W-EDM and I will make an AB nut for it.
    just like this one
    I was wondering, how could I calculate the preloading force of the spring. I know it must exceed the load of the carriage but how can I calculate it in terms of spring parameters?
    Will be waiting for reply,
    Mar 2005
    1673
    I can't really help but here's a link that might point you in the right direction for "spring parameters".
    http://www.engineersedge.com/spring_menu.shtml
    John
  1. pressure vs force
    By pit202 in forum Haas Lathes
    Last Post: 10-10-2008, 08:30 PM
  2. how to figure force?
    By jessslp05 in forum Linear and Rotary Motion
    Last Post: 05-06-2008, 02:43 AM
  3. Need to know how much force in psi
    By RedDog22 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-05-2008, 11:32 PM
  4. How much force on a cutter ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 06-14-2006, 08:04 PM
  5. Air cylinders, PSI & Force they have ???
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2006, 05:23 AM
