603,870 active members*
7,981 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Precise 650nm Red Cross Laser Alignment Review
    Jul 2014
    28
    650nm red cross laser alignment is quite different measuring tool. It adopts different output power and technical data alignment lens. By equipment of different data required cross generating glass cylindrical lens, this alignment laser will project different size two perpendicular lines with different laser beam fan angle. If there is no special requirement of lens degree, red cross laser alignment is just customized with 90 degrees glass cylindrical lens.
    According to different application requirement, this red cross laser alignment is just specially designed in order to fulfill all kinds of requirement in different working fields. It always chooses high quality 650nm red laser diode with import quality standard. By special configuration of high performance APC electric circuit board and glass coated optic lens, this cross generating alignment laser has just obtained superior advantages of high stability, high reliability, strong anti-interference, good coherence and long serving lifetime.
    This advanced configured cross laser alignment always gets super stable and reliable two perpendicular line generation owing to its perfect thermal emitting system. Under condition of 24 hours continuous cross generation, it has just assured high stability and high reliability. It is mainly workable for accurate cross generation of various machinery processing, textile garment positioning, industrial devices, medical treatment devices and laser positioning etc.
    Mar 2015
    40
    Re: Precise 650nm Red Cross Laser Alignment Review
    Quote Originally Posted by bosummer View Post
    i'm considering adding red dot to my machine, but i see that your offering is compatible both various machinery processing and medical treatment devices. don't you think its a kind of contradiction? it surely can be compatible with both at same time. what kind of adjustment you need to do when you change from textile positioning to acrylc positioning? as far as presision, any chance to reduce it a bit?
    Jul 2014
    28
    Dot laser alignment can be focus adjustable. In front of the laser alignment head, you can try to screw the head part to change beam focus in use.
  1. Unique Cross Projecting Green Laser Alignment
    By bosummer in forum Laser Hardware
    Last Post: 03-17-2015, 07:04 AM
  2. Industrial Red Dot Laser Alignment Review
    Last Post: 03-09-2015, 08:22 AM
  3. Review of Efficient Pro Red Line Laser Alignment
    Last Post: 01-20-2015, 04:39 AM
  4. Berlinlasers Green Dot Laser Alignment Review
    Last Post: 07-20-2014, 09:47 AM
  5. Line or cross hair laser alignment
    By dkrenfrow in forum Commercial CNC Wood Routers
    Last Post: 11-21-2012, 03:43 AM
