Tek,
How is the build going? I keep going back to your "obligatory" weld pic, is the lack of splatter from the pulse feature? I do not see any sticky anti spatter. I like the way the weld is equal on both up and flat, it looks like you turned it 45deg to make a "flat weld". Most of the welding we do has to be flat because of the liquid state of the spray. We spray transfer with argon and oxygen (variable) and magnetic transfer/impregnate tungsten carbide grit into the liquid puddle.
WSS
