603,794 active members*
3,628 visitors online*
Thread: Press Brake
    Nov 2010
    Press Brake
    I would like someone to explain me how to estimate bending cost with press brake? I am a water jet operator and estimation for water jet cutting is really simple but I can't figure that out with press brake.Do we have to use a software or is there way to do it by hand? any help will be appreciated!!
    Dec 2007
    32
    Call the machine time $80 an hour for setup time most setups will take between 3-20 min and then cost per each bend whether it requires two or more pieces. So on and so forth
  1. Looking to buy Used Press Brake
    By magma-joe in forum Bending, Forging, Extrusion...
    Last Post: 01-16-2012, 09:05 PM
  2. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  3. Press Brake
    By davesnd in forum CamSoft Products
    Last Post: 12-02-2009, 07:11 AM
  4. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
