603,818 active members*
4,148 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Pressing reset changes G54 values to zero.
    Nov 2003
    17
    Got used Kitamura with 16i controller and when reset is pressed, the G54 values change to zeros. Is there a parameter to change this?
    Thanks for any help.
    Kirk
    Aug 2011
    2517
    Re: Pressing reset changes G54 values to zero.
    check/try...
    1201 bit 7 = 1 (upon reset, work coordinate system is returned to that specified with G54)
    in this case a reset will always return you to your G54 workshift
    1202 bit 3 = 0 (local coordinate system is not cancelled by reset)
    in this case a reset has no effect on any workshift setting and will remain valid until cancelled with another work coordinate system G code.
  1. pressing bisalloy400 into a disc
    By mallee in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2012, 05:38 PM
  2. Pressing Reset in Mach3 set Machine coords to 0?
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-21-2012, 04:21 PM
  3. Pressing on in spite of temporary doubts
    By cncadmin in forum EnRoute
    Last Post: 02-10-2012, 09:10 PM
  4. pressing problems.
    By fmcbrandon in forum Maintenance DIY Discussion
    Last Post: 05-27-2011, 10:15 PM
  5. Fanuc m15 how do I reset limit(s) values?
    By stoney459 in forum Fanuc
    Last Post: 01-08-2011, 01:15 PM
