I have searched the “heck” out of this site looking for an answer and trying to avoid repeating a question, so if I missed something, please let me know…..
I have a question about “pressuring” the Pinion into the Rack to reduce backlash. I have read that the larger the diameter of the pinion gear, the less likely it is going to “jam” or “stick into the rack, but the trade off is the gear ratio increase. Also, the 20 degree pressure rack is better than the 14.5 degree pressure rack for this use. However, I can’t find any info on “pressuring “helical racks.
Originally, and mostly due to the weight of our gantry, we had decided on larger 34 frame motors, spinning in 25:1 gear boxes, with a 18T / 1.50” diameter “Helical Gear” pinion riding on a 26mm (1.02”) face width rack as supplied by Atlanta Drive. For the record, the motor plate is bolted to two THK Linear rails with dual cars on each rail (yes, I know….overkill). I what then planning on pushing up on the motor plate with either an Air ram or a gas shock.
1. Do / should / can we still “pressure drive” the pinion up into a Helical rack to further reduce the Backlash, and in doing so, what would be a good starting force pressure.
2. Would the use of a gas pressure shock(s) work as efficiently as an Air ram? I like the idea of two smaller force gas shocks that equal the total force needed as a redundant back-up system. I would rather not run the air lines, and pressure regulators.
3. Would I see the sticking problem with the helical pinion if the Diameter is 1.50”?
4. If the idea of pressuring the rack is not acceptable, would a “version” of a turn buckle type device that would be machined to the same size and shape of the gas shock/air ram work to adjust the pinion placement into the rack (still using the slides)?
Thanks in advance.........
