Originally Posted by
low_48
Lots of things to consider Bob. Taking wet lumber off the log into a closed space like a basement will cause the lumber to mold. You need enough dry movement to prevent this. Then consider the humidity level in the summer, and the wood won't loose much moisture at all. You also have to consider the chance that powder post beetle will infest the wood. They love wet wood, especially any sapwood. The wood has to be held above 130 deg. F for a time to kill the eggs that may have been laid under the bark of the log. One year in a basement is not long enough, and not warm enough. The only successful air drying I have done, is taking the stock to my garage attic in the summer. That is after it has air dried for a year under cover, outside. I have had powder post beetle problems in the past. The best home system is an insulated kiln that uses a dehumidifier and heat source. This can be a home dehumidifier, but the acids in oak are really hard on them. Google for a home system like that. Also, I wouldn't mix two species in the kiln at the same time. The poplar is going to dry much quicker and easier than the oak. White oak is really a ***** to dry, stick to red oak if you can. Good Luck.
Great points of consideration! Excellent post!! Here's some info that might help.
http://www.woodweb.com/KnowledgeBase...ingLumber.html
Web-site: http://www.innovative-accents.com/
Blog: http://blue-collar-nobody.blogspot.com/
