Hi all,
Why does TurboCAD print out my drawings larger than drawn? Like a 4.5" distance is printing at 4.7". Thanks
Hi all,
Printing is very different than plotting. When printing, look at the properties in the printer control window. Look for a scale setting. My guess is you are set to 'Fit to paper size' and you should be set to 100%.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Is anybody aware of a utility for converting the AutoCAD style 'stick' fonts that come with TurboCAD and AutoCAD? I would like to turn them into TrueType fonts for use with DeskEngrave and VectorCAD
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
TurboCAD uses the "stick type fonts" to be compatible with AutoCAD drawings. You also have an option in TurboCAD to use True Type fonts installed on your PC.
Mauritz
