587,628 active members*
3,245 visitors online*
Results 1 to 10 of 10
    Sep 2018
    11
    PRO 4896 Nema 23 Enough?
    I would like to order a PRO 4X8 for a hobby machine to cut mostly wood and perhaps dabble in making a few bucks here and there. Talking to CNC Router parts they thought that Nema 23 motors would be fine. I'm also impressed they did not want to up sell me. I hate buying twice and have zero experience with a router CNC.
    My question is...... Has anyone wished they would have upgraded to the Nema 34s? Is it just a matter of speed or will I have a better cut taking more bite? Can the machine even use that much of a motor? It appears it is about a $1200 more now or $2600 later. Reading the forum it seems that the majority go with the bigger motor. Maybe because they use it in a profession? I would pay it if it would be a benefit, and hold off on the Aspire software upgrade. I appreciate the help.
    Jul 2017
    42
    Re: PRO 4896 Nema 23 Enough?
    I have the Nema23's and I haven't run into a situation where I wanted the 34's or thought I needed them as a Hobby user. I was cutting 1/2" plywood with a 1/4" bit at 120 with a 1/4" pass and had zero issues. I kept increasing the speed to about 140 when I started seeing chattering and backed it off. My opinion, and take it for what it's worth, is the software might come in more handy. I didn't care too much about the speed since I'm using it just for a hobby.
    Mar 2003
    35538
    I'd go with Nema 34's.
    In addition to faster rapids, you can make deeper cuts, and higher acceleration, which can make a big difference.
    Fwiw, I cut faster than this on my plywood and skate bearing machine.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2015
    130
    My Pro4824 has Nema 23 and is strictly a hobby machine although I do occasionally cut pieces for sale. I have no problems cutting 150 to 300 ipm depending on the material. I cut mdf, hdpe, pine, walnut but mostly red oak. I also engrave soapstone, alum & glass. I'm usually not in a rush with my projects. If I were doing commercial work I would go with the 34s. I've never had a problem or wished I had more speed in the 2 years of owning my machine.
    Aug 2016
    122
    Me too. I have a 24x48 Standard machine with the 23's. No issues or regrets. I am a hobbyist. Mostly mdf, plywood, hard wood, a little brass/Al, a few circuit boards, slate, plastic, etc. Oh, Bosch 1617 bit spinner. Great setup for me anyway. The 34's wouldn't make any difference for me. I'd spend the money on bits and materials!
    I must admit, I have never been brave enough to go 300ipm! I stay around 125 or less at around 1/4" max depth or less depending on the cutter. I've broken a few bits, but usually because i rammed them into the spoil board - oops!
    Since you are new to this - don't discount dust collection.
    Enjoy your new toy!
    Tony
    Sep 2018
    11
    Quote Originally Posted by Goonk View Post
    Enjoy your new toy!
    Tony
    I have a cyclone dust collector in place for the future CNC. I just need to bring some pipe to it.
    Thanks for the replies guys. This makes me feel better about decisions. I went through the first part of my life trying to do with smaller and perhaps under powered to save money. Just want to get it right here, and getting a machine with the right stuff!
    Mar 2003
    35538
    And you're doing the same thing here.
    The end users expectations play a huge roll in what is "good enough" with a hobby CNC machine.
    People are constantly asking questions here that are difficult to answer, because the answer depends on your expectations.
    While plenty of people are certainly happy with Nema 23 motors on a 4x8, it doesn't really matter if they are or not.
    All that matters is if you'll be happy with them, and nobody can really answer that except you.
    Gerry
    Sep 2018
    11
    I did go with the Nema 23 motors. They seem to adequate for me at this juncture.
    Apr 2016
    54
    I run 570oz nema23 it can do 800 inch/min rapid but i had to do it again id spend extra bucks on close loop stepper instead
    Feb 2005
    829
    I have a CNC Routerparts Standard 4896 with Nema34. I routinely cut ply wood at 200-360ipm, and rapid at 1200IPM. I surface my table with a 2inch bottom cutter at 18k RPM at 400IPM.
  1. Stepper motor upgrade NEMA 34 or NEMA 42?
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2015, 04:59 AM
  2. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  3. nema 34 1600 oz or nema 42 3200 oz?
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 07-27-2009, 11:53 PM
  4. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
