587,772 active members*
2,933 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Pro Engineer-Prismatic Milling or Production Machining
    Klaus Guest
    Any users of Pro Engineer-Prismatic Milling or Production Machining?
    Do you know the capabilites of the above CAM systems?
    Klaus
    Jul 2007
    HI....Yep....i use them both
    complete machining essentially allows you to program up to full 5 axis interpolation toolpaths....
    prismatic is simply 3 axis
    if you go to ptc.com, you can download spec sheets there
    they are both excellent, especially if you require a paramteric link between CAD and CAM
    ben
