603,813 active members*
3,047 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > ?? Probe lost calibration ??
Results 1 to 4 of 4
    Dec 2008
    319
    Interesting...
    I have not ran any parts on our mill in a couple months. Last night I ran a part and set everything up with the probe. When I ran the program the probe had lost all information on its length.
    Is there anything that could have been done to make it lose calibration?
    Tim
    Apr 2005
    713
    My first thought is that somebody overwrote the probe's Z offset. That length is only stored in the tool offset page as far as I know.
    I keep that number written down just in case.
    Aug 2010
    579
    Lightbulb
    Tool offset is the most likely culprit, this can be remedied using the intuitive tool setup feature. Other possibilities are work, global, or wear offset values.
    calibration
    Are you saying that the tool length in the offset register is blank for the tool number that holds the probe?
    The battery life in the Renishaw probe and tool setter on my TM-1P is about 3 to 6 months depending on how often you use it. Just something else you might want to check if my first statement is not correct.
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://www.johnsmarinesolutions@gmail.com
  1. Renishaw touch probe calibration and accuracy
    By gpcoe in forum Haas Mills
    Last Post: 06-29-2010, 09:50 PM
  2. Probe calibration
    By kprice1658 in forum Tormach Personal CNC Mill
    Last Post: 10-25-2009, 09:56 PM
  3. Renishaw Probe Calibration & Ring Gauges
    By Donkey Hotey in forum Haas Mills
    Last Post: 12-07-2008, 09:39 PM
  4. Work Probe Calibration
    By JWB_Machining in forum Haas Mills
    Last Post: 10-27-2008, 03:42 PM
  5. Fanuc OT lathe probe calibration
    By Ztiggi in forum Fanuc
    Last Post: 03-14-2008, 07:36 AM
