588,489 active members*
4,332 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Problem about READ/PUNCH G-code with Fanuc 18T Model B
    Apr 2007
    10
    Dear All,
    I have some problems to Read and Punch G code into the Miyano Lx-21s with Fanuc 18T model B.
    My setting are
    TV Check : Off
    Punch code ISO/EIA : ISO
    I/O Channel : 0
    Baud rate : 10(4800)
    Data Length : 7
    Stop Bit : 2
    My laptop has serial port and can use with other machine perfectly.
    The Problems are:
    1. When I punch program out of CNC to my laptop, I always receive a bunch of characters that cannot understand.
    2. When I read program into CNC from my laptop, The CNC always alarm. The alarm random between "087 Buffer Overflow" and "079 Program Verify Error"
    I already try to fix by the following but cannot fix this problem :
    1. I change the cable both with Hardware and software handshake config. I also change the setting in the laptop as well.
    2. I try to change the baud rate 2400-9600. I change both in the CNC and laptop.
    3. I change the serial port in the CNC machine.
    What can I do next? Please help me to find the answer of this problem.
    Thank you you guys in advance.
    Mar 2003
    2932
    Re: Problem about READ/PUNCH G-code with Fanuc 18T Model B
    Check your Windows Control Panel - Device Manager - Ports and be sure the FIFO buffers are turned all the way down and unchecked.
  1. Replies: 0
    Last Post: 05-22-2014, 07:00 PM
  2. Replies: 1
    Last Post: 01-20-2014, 06:24 AM
  3. Replies: 3
    Last Post: 03-27-2013, 09:48 AM
  4. Replies: 7
    Last Post: 05-07-2012, 10:24 PM
  5. punch or read with fanuc
    By formulaz in forum G-Code Programing
    Last Post: 01-27-2005, 04:10 AM
