hello guys.
My problem is the connection between my Pc with a Fanuc controller GE Series 00-M.I don't know the parameters which I should change to achieve this connection,and the cable connections (9pin(PC)-25pin(controller)).The procedure to sent the data is the same with model 6m-b.If someone can help me,I will be very grateful.Also,does it need BTR(Behind tape reader);
