603,311 active members*
2,015 visitors online*
Results 1 to 8 of 8
    Oct 2009
    12
    Problem cutting sheet 3 mm help JIim Colt
    Hi all, I do not speak English well and I need your help, my Hypertherm plasma source 65 and control of THC torch candcnc not always end up cutting sheet metal, in the photo you can see the problem, the mass and properly installed and parameters are as indicated in the manual, this defect does not at the same point, from what can be the problem? thanks
    Jan 2008
    2247
    Re: Problem cutting sheet 3 mm help JIim Colt
    I would use 45 amp shielded consumables on 3mm material at book specs (from your Powermax65 operators manual). While you don't provide any details on what is your issue with cut quality....I can see a few things from your photo:
    - The cut height is varying. The top dross indicates the torch is too far from the material.
    - The pierce delay is too long...indicated by the large blow holes at the pierce point.
    Other than that...there is not enough information or pictures to help solve whatever your issues may be!
    Jim Colt Hypertherm
    Oct 2009
    12
    Thanks for the help, to cut the sheet I'm fine cut chart using shielded with the parameters set as written in the manual, the THC works and the loss of the arc is not always in the same spot, this morning I saw the design file and we many nodes are in the line, it is possible that too many nodes can be annoying to the path of the torch? the air and set to 100 PSI presents no moisture, and the flow constant, thanks
    Jan 2008
    2247
    OK....so are you saying the arc is extinguishing? If so:
    - Is there an error code on the Powermax digital readout? If so, what is it?
    -If no error code...then something in your part program or machine code is sending a stop command to the plasma. You will need to check that carefully.
    -It is also possible to have air starvation at the plasma air inlet.....this can cause the plasma to extinguish. You will need to install a pressure gauge right at the inlet (within about 100mm) and watch it carefully during the cut....if it drops below about 85 psi.....then you will need to improve the air supply.
    Jim Colt
    Oct 2009
    12
    no error code on the display, the incoming air and set at 100 psi, I am attaching the code of labor and job file
    Oct 2009
    12
    file
    Attached Files Attached Files
    Jan 2008
    2247
    Where is the pressure gauge located that you are reading the 100 psi on? Is the air flowing at the torch when you are setting 100psi?
    For the machine code...you will need to have someone that is familiar with Mach 3 (maybe go to the www.candcnc.com user group). I can help you with the plasma cutter....but if the program or machine code is shutting the plasma off....then you will need help with that.
    Jim Colt
    Quote Originally Posted by carlo66 View Post
    Oct 2009
    12
    The pressure gauge is 2 meters from the source, the air control and set to automatic, thanks
  1. I have a problem cutting on second half of sheet!!!!
    By LaserSpyder in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2014, 04:22 PM
  2. Replies: 0
    Last Post: 01-21-2014, 09:51 PM
  3. Excel Colt 510 with Fanuc OM problem
    By techscan in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2011, 01:41 PM
  4. Excel Colt 510 with Fanuc OM problem
    By techscan in forum Fanuc
    Last Post: 09-13-2011, 07:15 PM
  5. Nitrogen for cutting gas? (Question for Jim Colt)
    By magma-joe in forum DynaTorch
    Last Post: 12-11-2008, 06:34 PM
