587,082 active members*
2,711 visitors online*
    Mar 2007
    5
    Problem with CV mode
    Hello,
    I'm trying to mechanize a complex geometry composed for hundreds of small lines (G01 codes). I want the machine to move smooth, (since de lines are actually part of continuos bezier curve). So, i put the G64 code at first, in order to set the CV mode.
    But, it does't work as i expected. The machine did move smoth 10 or 15 movement, then stop, and start, makes another 10 or 15 movements, stop and start. The movement is smother than in exact stop mode, but yet it is not smoth as i need. It seems like the program only read 10 or 15 gcode lines ahead. I tryed all the opcions : angular discrimination, etc etc. Any suggest? I am using mach2
    Thanks in advance and sorry about my english.
    Mariano
    Mar 2003
    35538
    Not sure about Mach2, but Mach3 has a look ahead # of lines setting. You might want to try Mach3.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2007
    5
    look ahead
    Thanks for answer. I didn't find any look ahead option on the mach 2 configuration. So i will try mach3. I'll post what happened then.
    Mariano
  1. dro in manual mode...
    By triberman in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2011, 08:24 PM
  2. Phase mode without controller
    By Alex101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2007, 11:53 AM
  3. X in demo mode
    By mdlmkr in forum Mastercam
    Last Post: 10-28-2005, 02:53 PM
  4. EZ Trak Plus - G code mode?
    By zcases in forum Bridgeport / Hardinge Mills
    Last Post: 05-08-2005, 04:26 AM
  5. Fanuc tape mode
    By mroy0404 in forum Fanuc
    Last Post: 03-17-2005, 10:15 PM
