603,872 active members*
3,505 visitors online*
IndustryArena Forum > CAM Software > Mastercam > PROBLEM ENGRAVING
Results 1 to 5 of 5
    Nov 2010
    PROBLEM ENGRAVING
    Hello, I am using Mastercam X3 and trying to do some simply engraving on a flat piece of steel. I went to (create) and then (letters) and then positioned the simple stick letters on my part. My question is how do I create a tool path to follow the simple stick letters? I'm wanting to use a 1/8 ball cutter. It's nothing fancy, just for idenification purpose. Any help would be appreciated.
    thank Ron
    Dec 2005
    39
    The way I do it. I go to create letters first. Then I do a contour toolpath and select each letter. If you are using and end mill 1/8 got to XY stock to leave .062
    That will do it.
    I chain all the letters then turn my cutter comp from computer to off. This way the tool path will follow the center of the line of your geometry. This way there is no need to change your X Y stock to leave. This way it keeps it simple.
    Dec 2008
    3216
    use 2D contour
    select the chains
    select the tool
    Contour parameter settings
    Clearance = 1.0
    use only at start/end = check ON
    feedplane = 0.04 incr
    top of stock = 0 incr
    depth = ( say -0.01 ) incr
    comp type = OFF
    XY stock = 0
    Z stock = 0
    depths = OFF
    Lead in/out = OFF
    Dec 2008
    717
    Create the letters like you have, then just click the contour toolpath. Window around the letters and then it prompts you to click a start point. Click where you want to start, and it will grab all the other numbers or letters that are inside the window.
    Then set your compensation type to off (like the mad etcher kind of said). This is a simple way to get text.
    Tim
  1. Rotary Engraving Problem
    By coykiesaol in forum FlashCut CNC
    Last Post: 09-19-2010, 05:02 AM
  2. glass engraving problem
    By loyedp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2010, 10:49 AM
  3. laser engraving problem
    By fish09 in forum Engraving Machines
    Last Post: 02-04-2010, 02:02 AM
  4. Strong SG-40A engraving problem
    By takker in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2009, 11:00 PM
  5. Text Engraving II (Problem...HELP!) :)
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 01-02-2009, 02:44 AM
