603,912 active members*
3,343 visitors online*
    Jul 2006
    24
    Problem with Fadal post
    I am using Surfcam 2004 and when I post drilling and tapping cycles it produces a z move on the first line of the hole pattern. I didnt have a Format 2 post with rigid tapping so I reworked the Format 1 with RT and everything is works except the extra z. It doesnt affect the drill cycles only the tap cycle. if I dont manyall take it out the machine will alarm out. Can anyone help with how to fix the Pst file so that it wont produce this extra z.
    The post looks like this.
    M6 T3 ( Tool Radius 0.095 Diam 0.19 Corner Rad. 0
    G0 G90 S200 M3 E1 X-4.5669 Y-0.2475
    H3 M8 Z1.
    G84.1 G98 S200 R0.1 Z-0.5571 X-4.5669 Y-0.2475 F8.3334
    Y-0.8775 Z-0.5571 (This is the z I am talking about.)
    X-0.472
    Y-0.2475
    G80
    My post file looks like this.
    name FadaL 2 Rigid Tapping
    % 00
    ! 00
    / 00
    O >4
    N >4
    g >2.1 G
    G >2
    S >4
    H >2
    D >2
    M >2
    T >2
    R ->3.>4
    r +->3.>4
    z ->3.>4 Z
    E >2
    X ->3.>4
    Y ->3.>4
    Z ->3.>4
    I ->3.>4
    J ->3.>4
    K ->3.>4
    F >4.>4
    Q ->3.>4
    P >4
    L >4
    ( 00
    d >3.>4
    e >3.>4
    f >3.>4
    * 00 ""
    ModalLetters X Y Z F R # List of letters that are modal
    ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 84.1 85 # List of g codes that are modal
    Sequence#s N 0 1 1 # Char, freq, incr & start
    First#? Y # Y or N 'Output 1st sequence no.
    Last#? Y # Y or N 'Output last sequence no.
    HCode X # X or X U 'Horizontal char.
    VCode Y # Y or Y V 'Vertical char.
    Dcode Z # Depth char.
    FeedCode F # Feed rate char.
    Comment ( ) # Begin End comment char.
    Spindle 3 4 5 # Cw, ccw & stop m codes
    Coolant 8 9 7 # On, Off & Mist m codes
    DComp 41 42 40 # Left, Right & Cancel m codes
    LComp 43 49 # On & Off codes
    Feed G1 # Linear move
    Rapid G0 # Rapid positioning word
    Cw G2 # Circular move clockwise
    Ccw G3 # Circular move counter clockwise
    Inc/Abs G 91 90 # Inc & Abs char. & values
    CtrCode I J # I J or R or I J K L
    Helical? Y
    Spaces? Y # Y or N 'Spaces between words
    Incremental? N # Y or N 'Inc or abs output
    CtrIncremental? Y # Y or N 'Inc or abs I & J
    ByQuadrants? N # Y or N 'Break arcs at quadrants
    UppercaseComments? Y # Y or N 'Require uppercase comments
    WorkDefault 1 # Work offset register default
    Drill # Drilling canned/manual cycle
    G81 G98 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Peck # Pecking canned/manual cycle
    G83 G98 R[Vclear] z[D] F[FRate] Q[VBite] X[H] Y[V]
    end cancel
    Tap # Tapping canned/manual cycle
    g84.1 G98 R[Vclear] z[D] X[H] Y[V] F[Frate] S[Speed]
    end cancel
    LTap # Left handed tapping cycle
    G74 G98 R[Vclear] z[D] F[Frate] Q[VBite] X[H] Y[V]
    end cancel
    Ream # Reaming canned/manual cycle
    G85 G98 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Bore # Boring canned/manual cycle
    G86 G98 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Back # Back boring canned/manual cycle
    G76 G98 R[Vclear] z[D] F[FRate] Q[Sclear] X[H] Y[V]
    end cancel
    Cancel # Cancel a canned/manual cycle
    G80
    end
    StartCode # Start of the program
    %0
    O[Program#]
    End
    1stToolChange # First tool change
    M6 T[Tool] (0 d[ToolRad] e[ToolDiam] f[corner]
    G0 G90 S[Speed] M[Direct] X[H] Y[V] E[Work]
    H[Lcomp] M[Cool] Z[D] D[DComp]
    End
    Infeed # Enable cutter comp
    G1 G[Side] X[H] Y[V] F[FRate]
    end
    Outfeed # Disable cutter comp
    G40 X[H] Y[V]
    Z[D]
    end
    ToolChange # Secondary tool changes
    M5 M9
    G0 G49 G90 Z0
    End
    EndCode # End of the program
    M5 M9
    G0 G49 G90 Z0
    E0 X0 Y0
    M6 T[Tool1]
    M2
    %0
    End
    replace "d" with "Tool Radius "
    replace "e" with "Diam "
    replace "f" with "Corner Rad. "
    Jul 2005
    42
    Change all small z to capital Z corrects the problem
