587,313 active members*
3,355 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > problem with fanuc OT- parameter 8123 and 8124 is zero???
    Nov 2014
    7
    hello dear friends
    i am new in cnc .maybe my question very simple for you, i apologize for this.
    my machine before go to refrence work in auto mode so it is dangerous.
    i want to chang this.
    i read the parameter manual and change parameter 74 but not ok.please help me my friends .
    my other question is:
    parameter 8023 and 8024 for numerator and denumerator .but in my machine is zero.
    why is reason , i am very confused please help me.
    Sep 2010
    125
    Re: problem with fanuc OT- parameter 8123 and 8124 is zero???
    For the automatic zero return, this is made by your pmc, not by fanuc, so look your ladder , may be you have a keep relay to cancel that
    for your parameter, i think your machine use the flexible gear and at this time, parameters 8023 24 are not used
    Nov 2014
    7
    thanks a lot for your answer dear friend.
    yes i think your answer is true .but i have not any manual for keep relay in for machine
    which signal , i must search in pmc ladder for reference .
    and for flexible gear what is difference between use flexible gear in machine with use numerator ??
    best regards
    hamid
  1. FANUC 0T parameter problem
    By kreutz in forum Fanuc
    Last Post: 06-09-2022, 02:03 PM
  2. Om Fanuc parameter problem
    By Dean Monarch in forum Fanuc
    Last Post: 04-12-2014, 07:55 AM
  3. Fanuc OT parameter problem (EMCO 320 Lathe)
    By archfact in forum Fanuc
    Last Post: 03-17-2014, 08:48 PM
  4. fanuc 6t parameter problem
    By moghul in forum Fanuc
    Last Post: 12-30-2011, 07:59 PM
  5. Fanuc OM ATC parameter problem
    By techscan in forum Fanuc
    Last Post: 09-18-2011, 04:49 AM
