603,884 active members*
5,612 visitors online*
Results 1 to 6 of 6
    May 2011
    Problem - GCC New Mercury
    hello
    I bay gcc laser New Mercury. If I send graphic on laser, sometimes file will do "stop-freeze" on PC printer front and I must extract USB connector and push in back and print again.
    you do not know ....where is problem??
    Jul 2008
    776
    First of all do proper grounding. Unscrew any screw from laser body and with sandpaper remove paint absolutely. Buy copper wire and connect this screw to grounding contour.
    May 2011
    Hello
    Thanks for answer. I try your help but problem is always :-(
    Jul 2008
    776
    Change USB cable, delete and install printer once more. What is your OS?
    May 2011
    OS is WIN XP 32bit. Cable and delete and install printer once more.... I was trying.
    Jul 2008
    776
    1) How often this happened
    2) When you got this laser? If within last two months - check PM in 30 min
    3) May be you can reload firmware?
    This problem is unusual for Mercury
  1. reparación LaserPro mercury
    By osaro in forum Spanish
    Last Post: 02-06-2014, 08:39 PM
  2. Help required: Rotary engraver GCC Laserpro Mercury II
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2011, 02:38 PM
  3. Ted's Tsugami Mercury NCM 45 Lathe Retrofit
    By laserted in forum Uncategorised MetalWorking Machines
    Last Post: 10-29-2009, 03:43 PM
  4. Mercury
    By Mercury in forum Composites, Exotic Metals etc
    Last Post: 02-09-2009, 09:34 PM
  5. Mercury Press Brake. Where to get info & parts?
    By douglasco in forum Bending, Forging, Extrusion...
    Last Post: 09-03-2008, 05:49 PM
