It's been a little over a month since I have done anything with my plasma table and have returned to a problem. The last time I used it, I cut out a test part and it worked fine. When I tried to use it the other day to cut out a part the torch fired and started to loop in and lower itself to the cut height, it pierced thru the metal then the torch lowered to the steel and shorted out which stopped the program. I have a TD cutter and the blinking lights indicated that the fault at 85 psi with 5 blinks per second was a temporary short, turn it off then back on and it is fine. I tried to cut out a square a couple hours ago and it cut one side of the square and part of another side before the torch went down to the steel and shorted out again and dragged about a 1/4" before it stopped (it has done this twice) all the other times it pierces the steel then thats it. Any Ideas of what is wrong?
