588,344 active members*
5,603 visitors online*
    Sep 2004
    Problem milling MDF.
    I am a newbe with a tabletop CNC router table which uses a Rotozip.
    When cutting MDF with a new 1/4 inch two flute carbide end mill, the edges of the material are left rough and frayed. Depth: 0.10, Feed: 60 ipm, RPM: 15m.
    I am producing molds for casting urethane rubber which will be used to cast plastics.
    Any suggestions on other inexpensive milling substrates would be appreciated.
    Thanks, Jim
    Jun 2005
    194
    Jim,
    This was posted awhile back.. See if it helps.
    Good luck,
    Attached Files Attached Files
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Sep 2004
    JR
    Many thanks for the speed rate guide. Based on this, my rpm is set too high. I will make the adjustment and run a test.
    Regards, Jim
