587,633 active members*
3,242 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Problem moving servo coolant from A-axis to B-axis on a Fadal
Results 1 to 4 of 4
    Sep 2009
    105
    I have a 4525 with the Servo coolant set up as the A-axis. I will be installoing a 4th axis Rotory in the A-axis slot so I wanted to move the servo colant to the B-axis. This machine is a 2003 and has 1010-6 boards. I moved the jumper on the board, slid the board into the "B" slot and changed the parameters to X,Y,Z,B. The Computer doesn't like it as it won't allow me into jog unless I'm in MDI and doesn't move the servo in B at all when I'm in jog. The book says that the servo coolant should be in the B-axis if you have a rotary in the A-axis so I know it can be done. I have a fair amount of Fadal experiance but none with Servo coolant or B-axis. Wonder if I'm just missing something.
    Jun 2005
    Re: Problem moving servo coolant from A-axis to B-axis on a Fadal
    Did you change the B axis ratio to coolant under parameters?
    Sep 2009
    105
    Yup. Didn't make a difference. I'm going to move the A Axis and then try the Servo coolant in B with a different board later.
    Jun 2005
    OK Keep me informed I'll be in the same boat soon.
  1. Fadal all axis problem
    By jack123529 in forum Fadal
    Last Post: 12-08-2017, 03:37 PM
  2. Strange problem with moving X axis all of a sudden
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-27-2013, 10:24 PM
  3. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  4. Mach3 y axis dc servo jumps when moving small increments only.
    By mif73 in forum Mach Software (ArtSoft software)
    Last Post: 09-15-2008, 09:32 AM
  5. Replies: 5
    Last Post: 11-04-2007, 07:41 PM
