603,960 active members*
3,790 visitors online*
    Sep 2008
    Unhappy Problem with my EZTRAK 3-axis
    Hi
    I have one EZTRAK 3-axis with version 4.00/5.66 and up , series II REV. AA, I having problems with the machine, when star to run one program at any diferent part of the program the machine stop and turns off (the screen) is only running the spindle, also the machine stop too when a touch the keyboard, we clean the control panel and the keyboard, clean the filter, fans, even use another keyboard, but nothing happen, can you help me please?
    Chema
    Dec 2005
    3319
    shut machine off
    First unplug the machine Kboard and plug in regular keyboard inside cabinet.
    Reboot and exit to DOS once boo up finishes .
    Run C:\DEFRAG.
    Then run C:\SCANDISK
    If SCANDISK finds/shows errors, you can have it fix them. If SCANDISK can not fix, you may need to replace HDD.
    If by chance you have a new HDD that is not of BPT formatting, this could be your problem - BPT format is 504MB ONLY. Larger size format will NOT WORK!!!
    When replacing HDD, you have to partition C: drive to 504MB ONLY. or else software will get scrambled as data is stored. You will have to reload software on new HDD from back up disks.
    YOu do have B/U disks I hope.
  1. Bridgeport EZtrak startup problem
    By premierpatterns in forum Bridgeport / Hardinge Mills
    Last Post: 01-27-2010, 10:37 AM
  2. Problem with my EZTRAK 3-axis
    By Ingchema in forum Trade Shows / Webinars / Other Events
    Last Post: 09-16-2008, 01:59 PM
  3. EZTRAK DX II Problem
    By JPMProto in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2006, 03:12 AM
  4. eztrak sx problem(s)
    By DGeoLab in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2006, 03:18 PM
  5. EZTrak with factory installed 3rd axis.
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2006, 07:13 PM
