603,982 active members*
2,664 visitors online*
Results 1 to 19 of 19
    Mar 2006
    79
    problem with my z axis on mach3
    can any one tell me why when i start to cut any part my z go all the way down to the last part i set up my g code on lazycam and still go dip i have not cut anyting yet any of my trys are bad i get a dip holl in the part
    Mar 2006
    79
    well after waching some of the videos and i really don't know how it worcks on the mesuments for the lazycam dose it worck on mm or inches what i have to do the ticnes of the matirial is 1/4
    Mar 2003
    35494
    Can you post 20-30 lines of your g-code?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2006
    79
    N5 (File defeuser 10333 )
    N10 (Default Mill Post)
    N15 (File Posted in Mill Mode)
    N20 (Monday, April 02, 2007)
    N25 G90 G80 G40 G91.1
    N30 G0 Z0.0000
    N35 X33.5026 Y36.0595
    N40 Z0.1000
    N45 M3
    N50 G1 Z6.3000 F3.20
    N55 X33.1585 Y35.5989 F100.00
    N60 G2 X43.5485 Y40.8064 I3.8900 J5.2075
    N65 X33.1585 Y35.5989 I-6.5000 J0.0000
    N70 G1 X33.5026 Y36.0595
    N75 G0 Z0.0000
    N80 X57.1395 Y56.5732
    N85 Z0.1000
    N90 G1 Z6.3000 F3.20
    N95 X56.7954 Y56.1126 F100.00
    N100 G2 X88.7646 Y72.1356 I11.9692 J16.0231
    N105 X56.7954 Y56.1126 I-20.0000 J0.0000
    N110 G1 X57.1395 Y56.5732
    N115 G0 Z0.0000
    N120 X57.1395 Y116.6209
    N125 Z0.1000
    N130 G1 Z6.3000 F3.20
    N135 X56.7954 Y116.1602 F100.00
    N140 G2 X88.7646 Y132.1833 I11.9692 J16.0231
    N145 X56.7954 Y116.1602 I-20.0000 J0.0000
    N150 G1 X57.1395 Y116.6209
    N155 G0 Z0.0000
    N160 X33.1295 Y158.0198
    N165 Z0.1000
    N170 G1 Z6.3000 F3.20
    N175 X32.7854 Y157.5591 F100.00
    N180 G2 X43.1754 Y162.7666 I3.8900 J5.2075
    N185 X32.7854 Y157.5591 I-6.5000 J0.0000
    N190 G1 X33.1295 Y158.0198
    N195 G0 Z0.0000
    N200 X122.0641 Y116.6209
    N205 Z0.1000
    N210 G1 Z6.3000 F3.20
    N215 X121.7200 Y116.1602 F100.00
    N220 G2 X153.6892 Y132.1833 I11.9692 J16.0231
    N225 X121.7200 Y116.1602 I-20.0000 J0.0000
    N230 G1 X122.0641 Y116.6209
    N235 G0 Z0.0000
    N240 X158.1280 Y159.8846
    N245 Z0.1000
    N250 G1 Z6.3000 F3.20
    Mar 2003
    35494
    Whatever units you draw your part with in your CAD program is what LazyCAM should use. Set the cutting depth to a negative number, -.25 to cut 1/4" deep. Before running the code, set the top of your part to be Z = 0.
    Gerry
    Mar 2006
    79
    well thats most of my confecion i was drawing in inch and still go dip
    Mar 2003
    35494
    Can you post your .dxf file?
    Gerry
    Mar 2006
    79
    dxf003
    here it is
    Attached Files Attached Files
    Mar 2003
    35494
    Do you have it figured out now? Your drawing is in inches, so you enter the info in LazyCAM in inches
    Gerry
    Mar 2006
    79
    so many Q? not know how to make them i do it in inc or mm i don't know why still doing it i don't know whats wrong with my machine i saw the videos on the mach3 web page and i have all the setups like is supposed to be and still do the same is there a way i can speak to some one and see what i am doing wrong
    thanks for the replays
    manny
    Apr 2007
    30
    G0z0
    Might check to see if your clearance height is set in negative instead of positive or Vise-versa. Just a guess. looks like you are raipiding to a Z 0 then machining above that.
    Mar 2006
    79
    thats somting ells i don't know whats what on this + or - i don't know how the machine is suppost to be
    Mar 2003
    35494
    Z+ should move up and Z- should move down. It sounds like you may have it backwards.
    Gerry
    Mar 2006
    79
    wow problem solve lol now how i fixit it is backw how the x and y are suppost to go lol wow i am so stupit well it happents when you a newbe
    Apr 2007
    30
    Deep Breaths!!!!
    Like Ger said, try programming the highest part of the work piece at Z.0 then you can easily see if your rapid positions are violating your part. Don't get discouraged, this is all normal in the world of programming, not uncommon to send an end mill right into tour table! Just try not to! You will get through it. One thing you can do is hit feed hold at the point that the tool is violating the part and read the program line, then you will at least have an Idea where to look for the problem. Trust me it is something simple and when you figure it out... you are gonna slap yourself in the forehead and say &^&*^$&&$&%$
    Hope this helps.
    Apr 2007
    30
    too much too little too late
    guess I was a little late on that one.. Good job Ger
  17. #17
    Mar 2006
    79
    well z axis the + go dow and the - go up what the x and y should do
  18. #18
    Apr 2007
    30
    here we go
    The way I think of it is : in and out is the Y axis (just like sex.. in is positive!!!) the X axis is then to you left and right.... and Right is positive. That work for you?
  19. #19
    Feb 2007
    57
    sounds like somthing set wrong
    sounds like somthing set wrong in the driver because line 50 of the code says
    N50 G1 Z6.3000 F3.20 should be going other way OOPPPS SORRY ger21 already answered this
  1. Mach3 with Taig Motor Feed Rate Problem
    By alt255 in forum Taig Mills / Lathes
    Last Post: 12-13-2006, 08:50 PM
  2. Mach2/Mach3 installation problem (laptop)
    By xyz100 in forum Mach Software (ArtSoft software)
    Last Post: 07-25-2006, 02:56 PM
  3. Mach3 converting dxf files problem
    By randyf1965 in forum DIY CNC Router Table Machines
    Last Post: 04-19-2006, 05:28 AM
  4. Mach3 limit switch problem on Ref Home
    By originator in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2006, 03:02 PM
  5. Mach3 Mill Pausing Problem
    By Lionclaw in forum Mach Mill
    Last Post: 11-14-2005, 07:05 PM
