603,890 active members*
4,691 visitors online*
    Jun 2007
    87
    Exclamation problem with offset adjustments
    Hi guys,
    I'm currently running on a nexus 350ym and the machine is perfectly fine when you're using mazatrol program but when we use an eia/iso program, the machine doesn't read all the adjustments in the wear compensation. Anybody here who knows what might be the problem? The control is 640T. Thanks in advance.
    Aug 2008
    11
    basic question but, are you G-Coding 4 digits with each tool?
    For instance, Tool #1 = T0101
    Check for Tool digit errors as well. Sometimes, a tired programmer can slip in an alphebet "O" for a numeric "0" on a tool or part of code and it can be hard to spot.
  1. Problem with drive speed offset compensation by PLC programme
    By toninlg in forum Servo Motors / Drives
    Last Post: 12-13-2007, 07:42 PM
  2. Offset problem
    By smittys800 in forum Haas Mills
    Last Post: 06-17-2007, 07:08 AM
  3. Tool Change Offset problem on 3T control
    By Andy Kveps in forum Fanuc
    Last Post: 02-25-2007, 05:36 AM
  4. tool offset cancel problem
    By zoeper in forum DNC Problems and Solutions
    Last Post: 04-25-2006, 04:46 PM
  5. Being driven insane by an offset problem!
    By Cold Fusion in forum Uncategorised CAM Discussion
    Last Post: 09-12-2004, 04:39 AM
