587,998 active members*
1,991 visitors online*
IndustryArena Forum > CAM Software > MadCAM > problem recalculating previous toolpaths
    Jan 2015
    13
    Routinely, if I open an existing rhino file and then select a model and a toolpath and then ask to recalculate the pre-existing toolpath I will get an error msg: "this toolpath contains no valid search path to the cutter tool!"
    These are toolpaths that have worked just fine previously, which have been sent to post processor, and for which a tool has obviously been previously assigned.
    So, I'm not sure why this happens.
    Reason for wanting to do this is that I want to review the settings that I previously used in the production of a particular toolpath.
    S. W.
    Apr 2003
    1357
    Re: problem recalculating previous toolpaths
    Have you set up machining templates with various tool libraries? I just tried it and it works fine for me. We will need to verify that your madCAM is set up correctly. Can you review this post and let me know if this is how you are doing it?
    http://www.cnczone.com/forums/madcam...-wincnc-2.html
    Look at post #17.
    Thanks,
    Dan
    Jan 2015
    13
    Dan,
    Thanks much! I had not set that up. Didn't even know that process was necessary. I'm guessing that will solve the problem for me.
    SW
  1. Problem with finishing toolpaths
    By Chalyons in forum MadCAM
    Last Post: 06-06-2015, 04:20 AM
  2. problem with 5 axis indexed toolpaths
    By neptunier in forum MadCAM
    Last Post: 12-11-2014, 01:27 PM
  3. Solidcam transform toolpaths around 4th axis problem?
    By jsclark in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-01-2014, 10:44 PM
  4. Problem making toolpaths on a SLDPRT file
    By frejaspecial in forum Mastercam
    Last Post: 11-23-2012, 11:50 AM
  5. Replies: 3
    Last Post: 07-27-2006, 07:38 PM
