I am a CNC Newbie and I have a X6 1500GT and am using a licensed copy of MACH3.
I got it setup all ok, but the one small problem I can't find any clues for is when I click on the plus arrow to increase spindle speed, the display increases, but the actual spindle speed decreases, and vise versa.
I've googled until my eyes bled, but I can't find anyone with a similar problem or a solution.
If I was using a Printer port I would suspect that I had two pins configured,arse about, but I'm not....
I've asked 'Lance' but his written English is so poor he doesn't understand my question and I don't understand his answers.....
It *seems* to me to be a Mach3 configuration problem but I can't see anything that might fix it. I followed the setup guide and everything else is working.
There's only 3 wires going to the VFD from the USB Motion card, a 0 to 10V signal to change the speed (I assume) a ground and a direction signal for the motor, so the voltage much ramp up and down. ( haven't measured it, but it must do.... )
Has anybody had this problem? Can you tell me how to fix it?...
