I tested each motors on the functional Y, they work.
I have already done allot of searching and have tried everything recommended in regards to ports and pins.
It appears to be a HY-TB4DV-M 4 axis TB6560.
X and Y lock when powered on, Z stays turnable by hand and does not move during operation.
X is only turning in one direction.
im using a 36volt PSU.
my dip switches are all set to ON.
im running windows XP SP3.
my port & pin settings are
port 0x378 enabled
kernel set to 35Khz
Motor Outputs
X enabled 16 1 disabled disabled 1 1
Y enabled 14 7 disabled disabled 1 1
Z enabled 3 6 disabled disabled 1 1
A enabled 9 8 disabled disabled 1 1
Output Signals
Enable1 1 4 disabled
Enable1 1 17 disabled
Enable1 1 5 disabled
Ouput1 1 2 disabled
