I personally use a metal crucible. Heat it to red heat before using it to buildup an oxide layer to protect the steel from the motel aluminum. Always check your crucibles before using them with a tap from a hammer and toss it out if it's suspect. Steel pipe with a endcap welded on works well.
As for your fuel source are you using charcoal you buy for barbeques? If so I'm not sure its the best option as a large component of it is clay binder etc. I've used two setups, my first was a waste oil burner (messy and a pain to get started) and my second was propane. I prefer propane! There are a few ways to make good propane burners, A simple homemade propane burner is a good place to start.
WARNING - be very careful! Always wear protective equipment and ALWAYS watch out for water. A explosion of molten metal in your face will ruin your day!
