587,935 active members*
4,348 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Problems with NC communication
Results 1 to 5 of 5
    Mar 2013
    156
    I tried to upload a program to my Hurco Md3 ultimax II tonight and had zero luck.
    I had everything working 2 weeks ago. I used sheetcam to cam the autocad drawing.
    This was a smile job, a 12 x 12 "G".
    I tried every combination of settings. 7,1 even and 9600 is what I think I had originally
    I also checked the com setting on the PC, and sheetcam .
    So any idea?
    How can I tell if the cable is good? How about the PC com 1 port?
    Steve
    Aug 2005
    124
    Re: Problems with NC communication
    Still dead in the water or OK now?
    Mar 2013
    156
    Underdog-
    Still not working. The good thing is most of my stuff can be done by conversational programming. I do need to get it fixed. Just not sure where to start
    Aug 2005
    124
    Try sending from control to PC, its less finicky that way and you will see stuff coming sooner than the other way (less parameters to match). I'll try and check my parameters and get back to you. 7,1 even sounds right.
    Start, Control panel and System get you to devices and yes the com port must be set to the same settings. Of the three, control, cable and pc, do you have any idea which might have changed? Lightning storm? Moved stuff past the machine thus loosening the cable? Ran the exec tape on the control? This could narrow it down.
    Mar 2013
    156
    Underdog-
    About 4-5 months ago I had to have the service tech out. The controller was freezing for no reason. So he swapped several boards, and he replaced the memory batteries. The batteries help the most. If it did freeze, we could power down the machine, and not loose all the information and programs.
    I forgot what else he changed, but the everything was better.
    I was able to use sheetcam and connect to the mill before the problems. The problem is I don't use Sheetcam that often, so I am not sure when it stopped working.
    I will try to sent the controller information to the pc today.
    Thanks steve
  1. Communication Problems with PC
    By MarioEatsBk in forum Fanuc
    Last Post: 09-25-2013, 12:32 AM
  2. Meldas 520 Communication Problems
    By daz87 in forum Controller & Computer Solutions
    Last Post: 12-17-2008, 01:50 AM
  3. Fanuc communication problems.
    By mylo in forum Fanuc
    Last Post: 03-14-2008, 05:40 PM
  4. R2E4 communication problems
    By robthomas in forum Bridgeport / Hardinge Mills
    Last Post: 10-23-2007, 05:43 PM
  5. Communication Problems
    By dillweed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 04:12 PM
