587,171 active members*
2,867 visitors online*
Results 1 to 8 of 8
    Apr 2012
    11
    Problems setting up parallel port Mach 3
    Hi guys
    So i have got my cnc controller hooked up to a pc and everything is running fine with mach3.
    But i have another pc from which i want to run the cnc.
    To make sure i didn't make any config errors i copied the mach3 folder from one pc to the other. The problem is that i get no communication from the parallel port.
    The second pc has a lot more options regarding parallel port so i not sure what´s the best. I think ECP is the correct option, to i tried several variations on the settings with no luck. The relay on the breakout board does click when windows is booting so i assume it's not an hardware issue.
    I can also set the parallel port address to 378 (as is set in mach3) or leave in auto with no sucess.
    All the parallel port setting in both windows are identical so i assume it's not that either.
    Took some pictures:
    Any help?
    Any help?
    Regards
    Mar 2003
    35538
    Try EPP.
    What do you mean you get no communication?
    Did you run Drivertest.exe from the Mach3 folder?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2012
    11
    Hi
    srry for the late reply.
    There is no EPP only option. Only ECP + EPP so i assume that is what you mean.
    The no communication statement means i cannot control or read back anything from the breakout board. For example if i do auto-setup of pins, and press E-stop nothing gets detect, while in the other pc it picks up the correct pin for E-stop.
    Will try the Drivertest.exe.
    Tks
    Apr 2004
    5740
    ECP + EPP won't work (although you'd think it would). Look one more time in the BIOS- there might be some odd DOS thing you need to do to see the other options, like pressing Enter, then an arrow key. Sometimes down at the bottom of the screen there are instructions telling you what you have to do. Otherwise use this other computer for something else, and keep shopping...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Apr 2012
    I realize some time has passed since the OP posted this. I can offer my thoughts on how to fix this.
    In the original post, its stated that the OP copied the Mach 3 folder from the original PC to another. Mach 3 has to be installed on the new computer, the files cannot be copied from one location to another. During the installation process, the system registry is modified to tell the operating system how the new software interacts with everything else.
    Jun 2007
    3734
    Install Mach3 normally and only copy the .XML file from the other Mach3 folder.
    You parallel port might only be 3.3v and the BOB requires 5v.
    cnczone24 Guest
    sir plz contact on my email id [email protected] regard aniket kumar
    Jun 2007
    3734
  1. Mach usb/parallel port?
    By BjdfNtPT in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2010, 05:05 PM
  2. Add on PCI parallel port and Mach
    By RedLabel in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2009, 08:09 AM
  3. Mach, where's parallel port?
    By daisydog in forum Mach Mill
    Last Post: 09-10-2009, 04:40 PM
  4. Mach & PCI Parallel Port
    By JeLC in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2009, 11:33 AM
  5. Problems with parallel port
    By salvaCNC in forum Controller Cards
    Last Post: 10-09-2007, 03:00 AM
