I finally set up the 4th axis and tapping head today. I tried to tap a 1/2NC thread in to some plastic.
I have tried to a few different things, and all it seems to do is pull out the tap out of the collet. I doesn't even show any signs of reversing spindle when retracting.
Here is the code I am using, just one hole. Its a little butchered up because I have changed it a few times.
g54
g00g17g40g49g80 g90
m00t5m6(27/64 t drill)
s1000m3
g43h05
g00z0.2
x0.0y0.0
g83x0.0y0.0z-1.2r.2q.2f10.0
g80
m5m9
g91g28z0.0
m00
g00g17g40g49g80 g90
m6t10(tapping head)
m3s500
g43h10
g00z1.0x0.0y0.0
g1z-.8f38.46
z-.64f65.0
z.5f38.46
g1z.25
g94g00z4.0
m30
Am I missing something very obvious, I have tried several different methods for retraction. The large head has a reverse ratio of 1:1.75, with .160" until clutch engagement.
I have only rigid tapped or used tension compression holders on a CNC in the past. On a drill press self reversing tapping heads work great, I am a little bit baffled with the situation.
Could some one post a tapping cycle of there own to look at.
