587,458 active members*
3,659 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > procedure 6-sided processing
    Hello
    I am still quite new to this area so I have several questions: So far I “caped” almost all my parts (is that the right expression for that?) So I take the material about 5 higher than it needs to be, mill properly at the top and mill the contour all around. Of course that doesn’t always works.
    When I pre-work the overall dimension, then I first mill one side, turn the part about 180 degree and mill parallel to it. Now I have my parallel side so that I can mill side 3 and 4 now.
    For that, I take a shank cutter and mill sideways past side 5, so that it’s angular. ( if the vice is positioned straight on the table) Side 6 mill parallel again.
    Sooo now my question:
    What should I do when I cannot mill side 5 with a shank cutter because the part has the dimensions 100x100x100 and my longest shank cutter is only 40mm long. What do I have to do to get side 5 angular?
    Regards
    Manuel
    So I guess 5 axis processing is not possible and you don’t have a second machine with a horizontal spindle.
    If the requirement of the part is low, then I always adjust it with a hair angle, when I need it more accurate then I take a 50 square shoulder milling cutter from Igersoll with extension (100-250mm).
    <b><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->&#33;&#33; Mein alter Nickname: canon &#33;&#33;<!--sizec--></span><!--/sizec--></b><br /><br />Beginnt man das System zu hinterfragen, so erkennt man deutlich, dass die „Wahrheit“ zumeist entgegengesetzt des scheinbaren zu finden ist.<br /><ul><li>Wenn wir uns heute keine Zeit für unsere Gesundheit nehmen, werden wir uns später viel Zeit für unsere Krankheiten nehmen müssen.</li><li>Wenn es klemmt - wende Gewalt an. Wenn es kaputt geht, hätte es sowieso erneuert werden müssen.</li></ul>
    just common CNC machine is ok
