603,546 active members*
3,074 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Process of transferring the control program to the machine controller using a floppy.
    Post Process of transferring the control program to the machine controller using a floppy.
    Hi all!
    I recently managed to buy an EMCO TURN 120 CNC lathe with an EMCOTRONIC TM02 controller, in very good condition, and I faced such a problem as loading the control program into the machine.
    The controller has a floppy receiver, a floppy for 3.5 inch floppy disks and I, naively, dared to assume everything would be simple, you load the control program onto a floppy disk, and then insert it into the machine controller and load it into memory, but not everything is as easy as I expected .
    The controller does not understand the floppy at all, I tried to format the floppy in the controller, but it gives an error that the floppy is not ready. I note that the floppy disk is new and works properly.
    Maybe there is someone on the forum who has encountered such a problem, or maybe someone knows the complete process of transferring the control program to the machine controller using a floppy disk?
    The third day I try to understand how it works and there is no success.
    I will be grateful for any information.
    Best regards,
    Roman
    Apr 2022
    148
    Re: Process of transferring the control program to the machine controller using a flo
    You need software that called WinNC I think. It runs on windows95. And floppys formatted in DOS.
    Better read the manual https://manualzz.com/doc/18438809/ht...ce-emcotronic_...
    Thank you friend for your help, now I at least understand in which direction I should move.
  1. Cincom L25 E20 Over Run ERR when transferring from PC to machine
    By jamessayers in forum CNC Swiss Screw Machines
    Last Post: 03-01-2018, 10:49 AM
  2. transferring post processes to floppy
    By stohner210 in forum Autodesk CAM
    Last Post: 05-21-2016, 09:38 PM
  3. Transferring program with ethernet
    By mcv300 in forum Fanuc
    Last Post: 07-07-2015, 05:44 AM
  4. Replies: 1
    Last Post: 11-16-2013, 05:22 AM
  5. Floppy Controller card PCI floppy drive USB kit
    By logamuthu in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 05:23 PM
