Looking for a brass branding iron to be made. I will tap the handle, I just need the head made. The final iron should be about 1" x 4" and made from 1/2 " brass. I've attached a picture of what would need to be milled. The white back ground should be milled away around 1/8" allowing only the lettering to touch the wood to be branded.
You can call Chris with a quote.
301-693-8344
