603,964 active members*
1,999 visitors online*
    Hello
    We already had to help ourselves with DIN/ISO programs that were create don the machine.
    Does anybody know where you can get teaching material, programming examples and so on from?
    Hello
    If you need it for Röders then you find useable commands in the manual. You get a PDF version if you go through the surface of the controller using the big push button ‘HELP’.
    You can also copy it from the controller. As ‘teaching material’ I got told you can install the controller software without Dongle as a standalone-version on a desired computer (when you have BS WinXP like on the machine)
    How the commands are used should also be explained with some examples in the manual - depending on the command options on several surfaces.
    However we usually only adjust the BEF and don’t program anything on the controller.
    The controller almost only works with 3D programs that you can’t quickly program manually anyway.
    Regards Gerd
