603,942 active members*
3,804 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Program tool pot select on an umbrella?
Results 1 to 4 of 4
    Mar 2006
    45
    I have a Cadet-Mate 4020 vertical with a 700M control and a 20 position umbrella ATC.
    I have a job with several long drills and the part wants to go under the turret but some of the tools are long enough that they will hit the part.
    I want to change the tool, index the umbrella to a pot with short tools surrounding it and the do the cutting. Problem is I don't see an M code or any other way to move the umbrella to the pot I want.
    Any help on this would be appreciated. I do have User Task II if that helps.
    Thanks!
    Kev
    Jan 2008
    575
    I don't know if this will work, but have you tried just calling the tool without an M6, IE call the tool T1M6 and when the toolchange is done call T20 without M6. I don't know if it will work but it would, with the magazine changer.
    Robert
    The beaten path, is exclusively for beaten men.
    Mar 2006
    45
    Thanks but no this does not work. The machine knows it has to put the current tool away first so it holds the current position. Since there no ready station, tools always stay in the same spot in the carousel.
    Dec 2008
    3216
    So the spindle is used to pull the tool off/on the casousel, before indexing to take the next tool.
    One trick is to fill all the other pots ( with ficticious numbers) to stop the machine putting the tool back into another ramdom, empty pot.
    or
    Turn the long tool into a "large" tool, the pots either side become "dummy" pots and cannot be used , but this forces the machine to only place a large tool into a designated large pot
  1. MIT 320 UMBRELLA TOOL CHANGE
    By richard booker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2012, 06:49 PM
  2. VF Umbrella tool changer tilts tools
    By TEntpeg in forum Haas Mills
    Last Post: 08-08-2010, 10:42 AM
  3. Max Tool Dia. Umbrella Changer
    By twitte in forum Haas Mills
    Last Post: 07-01-2010, 02:36 AM
  4. Tool Change Recovery VF3 Umbrella
    By cncmaintenance in forum Haas Mills
    Last Post: 11-07-2008, 07:05 PM
  5. Program load/select list on V2XT Boss XT 3.4 control
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 02-23-2007, 03:36 PM
