Hello Guys,
On the F models, is it possible to transfer from USB to PCMCI Card?, i want to use the card as an extended memory.
Thanks!
Hello Guys,
Thanks!
Can't U use card reader on Your PC?
I am a bit confused what you are asking. with parameter 20 set to 4, you can bring a program into the CNC from the PCMCIA Card and them store in CNC memory then change parameter 20 to 17and output the files to the USB? There is no way to transfer between PCMCIA and USB as parameter 20 tells the CNC which to look for.
Maybe one of these USB-PCMCIA adapter-cards can do the job, I don't know that this will work.
Attachment 319150 Attachment 319152
Regards.
