603,890 active members*
3,964 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Program zero fro 4th & 5th axis
    Nov 2010
    Angry Program zero fro 4th & 5th axis
    I'm working on my first 4th & 5th axis project using Mastercam. I have no problem of programming but am confusing about the program zero.
    I understand that I can define a corner of the workpiece as program zero for a 3 axis program. But for 4th and 5th axis, the part will be rotated around and so the program zero. My question is:
    Is there a practical and safe method to define program zero for 4th & 5th axis?
    Please, explain.
    Or Mastercam will automatically compensate for the rotation of the program zero no matter where I define it?
    Mar 2006
    1013
    Dont shift zero for 4/5 axis. The part should be placed in the correct position, with World Zero being the Machine/Rotary zero point.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jun 2010
    60
    All depends on what machine controller you have.
    I've uased Mazaks and Heidenhein controls that compensate for the offset. So you can set the WCS anywhere on the machine.
    But the Haas machines I'm working on now don't, so one has to program to the centre of rotation. The part needs to be the correct distance and orientation from the WCS.
  1. how to program a 4th axis
    By cob in forum Mastercam
    Last Post: 02-19-2012, 01:00 PM
  2. Program zero for 4th & 5th axis
    By emsee in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-25-2010, 06:26 AM
  3. Why I program in 4/5 axis?
    By EL DUKE in forum EdgeCam
    Last Post: 04-29-2010, 08:07 AM
  4. Need help to program 4th axis move
    By garyatfj in forum Mastercam
    Last Post: 04-02-2009, 02:04 AM
  5. Need Direction on 4th 5th? axis program
    By Cappy in forum GibbsCAM
    Last Post: 04-21-2007, 01:20 AM
