587,418 active members*
3,670 visitors online*
    Nov 2008
    27
    programming the alphabet & numbers
    Hi is there a way to program the alphabet & numbers using a dynapath delta 20 I don't have it running off a pc thanks
    Oct 2006
    106
    The attached txt file can be loaded into the catalog. The attached pdf explains how to use program.
    This part program isn't fancy, but it accomplishes what you are looking to do. The downside is that you must make it part of your part program and call each letter and number as a subroutine. This takes up a fair amount of memory. But, you get what you pay for...
    Attached Files Attached Files
  1. Serializing Numbers
    By KaesynCAM_Tech in forum Okuma
    Last Post: 12-06-2009, 10:23 PM
  2. Line numbers
    By Eritex Inc. in forum Mastercam
    Last Post: 12-13-2008, 04:35 AM
  3. Round Numbers
    By stampman in forum Fanuc
    Last Post: 09-06-2006, 12:12 AM
  4. RFQ - 2 part numbers
    By mcmmach in forum Employment Opportunity
    Last Post: 05-19-2006, 04:18 PM
  5. Programming lathe with radius numbers
    By mudwhump in forum BobCad-Cam
    Last Post: 06-07-2004, 01:14 PM
