603,899 active members*
3,024 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Programming concave radius on Haas Lathe
Results 1 to 5 of 5
    Apr 2010
    I need to make a concave radius on a Haas Lathe. I am using a .375 Diameter round insert cutter trying to program a .228 concave radius on the OD. I cannot make a true radius.
    Mar 2003
    2932
    Please post your program here.
    Mar 2003
    2932
    Here's an example without tip radius compensation.
    Feb 2006
    992
    Quote Originally Posted by Wolf Pack View Post
    What's happen? A lot of factor involve that can make it go wrong. Post Your code and the picutre the part you cut, that will help us help you.
    The best way to learn is trial error.
    Apr 2010
    Concave Radius
    Sorry I couldn't get back in time to post my program, but dcoupar's example gave me what I needed. Thanks this was a big help!
  1. help programming radius cent V lathe
    By Joe Miranda in forum Milltronics
    Last Post: 05-24-2009, 03:40 AM
  2. Haas lathe programming question
    By machinistpaul in forum Haas Lathes
    Last Post: 05-21-2009, 02:41 PM
  3. Programming a radius
    By fukeneh in forum G-Code Programing
    Last Post: 07-14-2007, 03:35 AM
  4. haas lathe programming question
    By pavelbure in forum Haas Lathes
    Last Post: 06-17-2007, 04:17 PM
  5. Programming lathe with radius numbers
    By mudwhump in forum BobCad-Cam
    Last Post: 06-07-2004, 01:14 PM
