603,836 active members*
2,980 visitors online*
Results 1 to 20 of 20
    Jan 2007
    21
    Programming Mazatrol T1
    Please help me with programming mazatrol T1. I have experience with G-code.
    I need:
    - manual (part with examples)
    - simple software (like the one on the CNC) to edit, save and write programs on PC
    - communication software (CNC- PC)
    Best regards.
    Jun 2006
    478
    does your t1 use g-code or just Mazatrol?
    A.J.L.
    Jan 2007
    21
    just Mazatrol
    Aug 2005
    125
    for a manual - Mazak USA 800-331-9151 - (its too huge to copy-sorry)
    for editing and downloading software - www.solutionware.com (or www.solution-ware.com ??)
    Where is cro - thats all your location showed?
    Jan 2007
    21
    Quote Originally Posted by underdog View Post
    Cro - means Croatia this is a little country in Europe on Adriatic sea
    I need just a simple editing software(english language) to make programs on computer and send them to cnc because I have Swedish language on My cnc so it's very complicate to make programs on it
    Jun 2006
    478
    the only CAM software that I'm aware of comes directly from Mazak I think it's called MazaCAM
    A.J.L.
    Mar 2004
    761
    Quote Originally Posted by ajl6549 View Post
    MazaCam is made by Solutionware in San Jose, California.
    http://www.mazacam.com/whatis.html
    Also look for Camlink to edit Mazatrol programs
    http://www.griffobros.com/
    Wayne Hill
    Feb 2006
    992
    Diz
    My $.02, your demand Mazatrol offline programming will cost you few thousand..... Mazatrol is very different from other CNC language and you can't edit program without special software.
    The best way to learn is trial error.
    Nov 2006
    154
    For my $.02, one CAN edit a mazatrol program in, believe it or not, "notepad" which is in Win95, 98, and XP. I have used this many times after downloading from the machine to a laptop using Procom software.
    Steve
    Feb 2006
    992
    Quote Originally Posted by Newby2 View Post
    Steve
    Steve,
    Are you talking about 3-digit G-code or CMT Mazatrol? If you are successeful edit CMT Mazatrol show us how, I learn something new everyday.
    Dec 2006
    For saving/loading files you can use windows HyperTerminal works good and it’s free, or do Google search for free DNC lots of them around.
    Marcin
    Aug 2005
    125
    Steve/Newby2-WOW
    Steve/Newby2,
    WOW if you have been able to get Mazatrol out of a controller, edit it and get it back in without the use of multiple thousand dollar programs, PLEASE share! Many of us would put an icon on our screen for you if you have performed this feat.
    We'd like to know - version of Procomm, Mazatrol controllers you've used this with and any settings needed to make it work (type of data cable or pinouts etc)
    Many thanks
    Aug 2005
    125
    controller in Swedish?
    Diz,
    If I understand you coreectly, your Mazatrol controller's current titles and so forth are in Swedish. I know the controllers are loaded with several different language sets of titles for the exact reason that they want to sell these machines internationally. It might be a great help just to change the language of the screen titles.
    My manual lists the following numbers for Mazak in Europe. Remember this is an old manual.
    Yamazaki Europe - Belgium - 016-230902
    Yamazaki Germany - 7161-68057 or 68058 also 61057-1025
    Yamazaki United Kingdom - 0905-57024
    Good luck
    Nov 2006
    154
    Steve/Newby2,
    Many thanks
    To those that believe I have "hacked" into the mazatrol software this is not the case! Not smart enough to do do that, or, smart enough NOT to do that!
    What I am speaking of:
    After writing the program on the machine I download it to the hard drive of a laptop using a DOS version of Procom. There is a shortcut to this file on the desktop which will open the folder of the programs I have saved under a certain name. I open that file and am asked which program I would like to open the file with. I then click on either notepad or wordpad and the 3 digit G code version of the program is viewed. Once here, I can edit what ever I want to, save it and later on upload it to the machine.
    As far as editing the program, remember what the word edit means. Referring to the Programming Manual provided by the manufacturer, manual #H732PA0065E, chapter 8, "THREE DIGIT G-FORMAT", there is, as I can see, a complete description of what and how the program does what it does.
    It is completly different than what you see on the monitor of the machine.
    With this in mind, with the information provided in chapter 8, provided with the machine, (the programming manual), one could feasibly write an offline program, send it to the machine, and make a part.
    Again I must stress that I have not "hacked" into the Mazatrol software but have found, with the manufacturers provided manuals, that by reading what is contained in chapter 8, I can see the correlation between what I view when looking at the progran in notepad and what I see on the monitor when I program the machine.
    There is another post in this forum that also has information on this subject.
    Thanks and I apologize for the long windedness.
    Steve
    Nov 2006
    19
    Steve is right. It takes some thinking and a little bit of studying to figure out what the jumble of letters and numbers mean when you view a program in notepad. However, once you figure it out it becomes rather elementary programing. Just figure out where the G codes are in the programing and refer to the programming manual chapter 8 to figure out what the different G codes do. Then the x, y, and z axis as well as the feeds and speeds can be tweaked with. Shoot if you get good enough, one could write a whole program in notepad.
    Feb 2006
    992
    Well, the bad new for DIZ, his control is T1...... 3digits G-code is not avaluable, the control MUST be at least T-plus to do that.
    Anyone can hack CMT format to ASCII form without spend any dollar?
  17. #17
    May 2007
    194
    my mazatrol T1 does not communicate with the PC, I'm using EZATROL Demo with the cable type FANUC which is equal to that suggested by EZATROL, there is a parameter in the machine that I indicate the speed of communication
    Thank´s
  18. #18
    Jun 2013
    im a mazatrol T1 operator and programer..what can i do 4 u diz?
  19. #19
    Jun 2015
    5
    Re: Programming Mazatrol T1
    Me, too, I need
    - communication software (CNC- PC).
    Please share to me, my email: [email protected]
    Best regards.
  20. #20
    Dec 2015
    YOU GUYS SEEM TO BE VERY KNOWLEDGEABLE IN MAZATROL, WHAT IF I HAVE A MAZAK THAT HAS MAZATROL TURNED OFF IS THERE A PARAMETER TO TURN IT BACK ON. NO NEED FOR A MAZAK WITHOUT MAZATROL.
  1. Anyone out there like Mazatrol programming?
    By kappullen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2009, 04:57 PM
  2. Mazatrol T-4 programming help
    By machinist360 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-27-2008, 03:39 AM
  3. Mazatrol programming T-plus
    By Bobesmo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-31-2008, 12:18 AM
  4. problem with programming mazatrol t1
    By diz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-05-2007, 01:00 AM
  5. Programming Mazatrol T-Plus
    By toolmach in forum MetalWork Discussion
    Last Post: 04-02-2007, 11:39 PM
