603,890 active members*
4,691 visitors online*
Results 1 to 7 of 7
    Oct 2006
    11
    programming radius/ help needed
    Ok guys, im toiling here with how to write the programm for this radius, currently ive got the tool sitting at the 17.8mm length, but im stuck from there.
    Any ideas?
    By the way im using mazatrol and not EIA/ISO
    Cheers
    Gary
    Oct 2006
    11
    whoops, heres the drawing
    Dec 2006
    95
    Use your convex or concave options to do this.
    Oct 2006
    11
    Yes i know but i need to figure the start and end point, im new to programming
    Feb 2006
    992
    Let's start where you left off.
    Concave Start X=18.5 Z=? Finis X=18.0 Z=27(34-7) Rad=20
    Center X=58(20*2+18) Z=27 Intersect = up & right
    Concave Start X=18. Z=27 Finis X=18.5 Z=? Rad=20
    Center X=58(20*2+18) Z=27 Intersect = down & left
    Hit Calculate It should give you the endpoint. I program in quadrant since the dimension is given, I found it easier. But you can program in one line.
    Check Shape see they calculate it right.
    Hope it will help
    The best way to learn is trial error.
    Oct 2006
    11
    Cheers buddy, will give that a try.
    Jan 2005
    304
    radius
    Your start from the left end (in inches)
    X.728936 Z.162463
    X.712598 Z.275591 (MID POINT)
    X.728936 Z.388719
